Rear reflector re-seal - Help locating a past thread
Unable to locate the original thread - someone sucessfully disassembled and re-sealed a rear reflector. Like most of them, mine leaks a bit, and I am ready to try to repair if possible.
Anyone remember the thread?
Cheers!
Matt
Cheers!
Matt
I disassembled the rear reflector a few years ago. For me the trick was soaking in very hot water (in a bath tub) - it will soften the seal and becomes easy to seperate - the start is the most difficult and you want be careful not to snap the ends of the lens.
Edit: here you go: https://rennlist.com/forums/993-foru...-assembly.html
