Brake duct upgrade
One of the benefits of having the 993 up on jack stands is discovering everything that needed work that wasn't otherwise obvious. For example, I found my front driver's side jack point is collapsed, assorted screws and washers had been substituted in for the stock parts on the various covers, and spiders have lived and died by the dozens in every nook and cranny. And as the attached photos show, something else was missing. Photo 1 shows the passenger side front control arm. Note the brake duct. Photo 2 shows the same on the driver's side. Hmmm. I found and ordered the replacement part, but also started wondering how useful these are. This article indicates they are less effective on lowered cars, which mine is: http://www.dietersmotorsports.com/tech/2002/4-2002.htm
I wonder if anyone knows of an upgrade for the stock duct? I'd rather not fabricate my own if I can avoid it.
interesting read in your link posted above and I know this is not what your asking about but I think for front brake cooling upgrade many use these ducts.
http://www.fvd.de/us/en/Porsche-0/-/...Foglights.html
Just replace the stock duct and be done with it.
People run the foglight duct kits in conjunction with the stock duct, not in place of the stock duct.
The article you posted is interesting and definitely a worthwhile modification if you find yourself in need of more brake cooling, however, given that you discovered your broken duct only through visual inspection, not a deterioration in braking performance, it's probably safe to say that you don't need more brake cooling than what is provided by the stock configuration. Additionally, doing that mod will result in more broken brake ducts down the road, literally, since it will reduce ground clearance compared to the stock configuration.
It looks like the price of 964/993 brake ducts has gone up 250% since 2002.
Point taken. I am replacing with the factory part for now.
