Door handle trim gaskets
I am trying to replace the black plastic trim around the door handle on the outside of the door, there are two 8mm nuts on the inside of the door that hold the handle on, one is easily accessible, the other one closer to the door jam is the problem, does anyone know the best way to get to this nut.
This is what I used when I did mine. Very easy to do and I don't recall any problems.
https://rennlist.com/forums/993-1995...hange-diy.html
Thanks, for the info, I still don't see how you get nut #15 off I guess there is more stuff to remove around it, I'll keep looking at the diagram.
