Interior deck cover replacement options
I removed the rear seats and am planning on installing new carpet, probably using the Appbiz RS carpet kit since they offer it in blue, with some modifications. I want to retain the dark blue vinyl sides and deck, but the current deck piece has the Hifi speakers, and I am going with a stereo delete. I know I could try to re-cover the existing piece, but I am also considering buying a replacement instead. Does anyone have experience with this company? http://www.classic9leathershop.com/9...8-porsche-911/
The optional vertical seams are interesting, though I can't decide if they would look out of place in a 993.
Or has anyone used another company for the same part that they would recommend?
two ways to go wrt the rear deck,
use yours(or a spare) and fill the holes(usually a full inset in the top is best or the holes will print through the thin carpet) w/ l/w plywood or similar, then cover w/ carpet or vinyl or leather.
or cut foam to fit the space and allow for the wiring there, cover as above
either works the foam will be lower the other will match the arch of the oe vinyl one
I like the carpet from Lakewell it is a perfect match for the oe carpet
Bob was easy to work with and met deadlines.
Bob/Classic9 just did my rear deck. I did a speaker delete as well. I did vinyl on the top and leather on the bottom. The cost was $450 shipped. The hardest part of the whole process was finding a box to ship the deck in.
Anyway, it turned out great. I'll snap a photo later and post it up.
I look forward to seeing the photo.
I thought about having mine removed, but I don't think I'm going to be installing a roll bar. I had a DAS in my '87 911 and I didn't like the way it obstructed the rear window.
I'm sure if you have them removed, Bob can do a good job.
