Aaaghhh - Targa Top Disaster
#76
Marc
The kit I mention above is purely for the glass sections though, nothing for the sunblind which is missing from my car apart from a few bits of the mechanism - no doubt that will be another story but not one for 2014 considering what I have spent so far!
Regards
Roger
Regards
Roger
The shade is actually not that bad to put together. Nor is it very costly to repair if you need to. Just a little tricky to put together. Let me know when you are at that stage and I'll give you some pointers if you need it.
The glass mechanism is a much bigger deal. Putting those cables in without fully removing the tracks or back window is very tight. Since you're glass is broken in the back, replacing the cables before new glass goes in is a good strategy.
#77
Marc
Cheers, will bear it in mind when I get to the sunblind. It does look much simpler than the glass drive mechanism. For now, its a case of get the car back after painting, get the glass back in and get it working then just go drive the car and enjoy for a few months.
Regards
Regards
