993 Forum 1995-1998
Shock & Spring Upgrade
Old Sep 27, 2013 | 05:18 PM
zooming993's Avatar
zooming993
Default Shock & Spring Upgrade
I will be replacing the OEM suspension on my 95. Are there parts from the old shocks I’ll need to reuse? I purchased Bilstein HD’s and H&R springs and it appears I’m going to need additional parts (parts that didn't come with the shocks or springs) to mount the springs onto the shocks.
Old Sep 27, 2013 | 06:11 PM
P-daddy's Avatar
P-daddy
Yes, the top hats.
Old Sep 27, 2013 | 07:54 PM
Bill Verburg's Avatar
Bill Verburg
some springs are sized for oe spring mounts others not, check w/ H&R to determine what mounts your springs want
or check w/ a shop familiar w/ the job, where in NE are you located, someone can probably point you at a good shop.
Old Sep 27, 2013 | 08:39 PM
P-daddy's Avatar
P-daddy
OE mount
Old Sep 27, 2013 | 08:40 PM
zooming993's Avatar
zooming993
Thanks for the replies. Ok, so I'll be reusing the top hats. Right now the front springs do not sit properly on the shocks. The spring slides right over the large adjusting nut so it's missing something. I live approx. an hour north of Philly in Slatington, PA.
Old Sep 27, 2013 | 08:46 PM
P-daddy's Avatar
P-daddy
Not sure I understand you correctly. Are you saying the bottom of your spring doesnt have the height adjusting nut around the shock body to sit on?
Old Sep 27, 2013 | 09:08 PM
zooming993's Avatar
zooming993
What I'm saying is, the shock does have the adjusting nut but this nut alone isn't large enough to allow the spring to sit on. The inside dia. of the spring is larger then the outside dia. of the adjusting nut.
Old Sep 27, 2013 | 09:53 PM
P-daddy's Avatar
P-daddy
You'll have to reuse the bottom spring mount also for the front shocks. The rear shocks you don't, if I remember correctly.
Old Sep 27, 2013 | 10:07 PM
zooming993's Avatar
zooming993
P-daddy,
Thanks for your help. I've done some more research and you're correct, there is what's called a concave washer (964-343-503-00). So I'll need to reuse the top hats and these washers.
Old Sep 27, 2013 | 10:20 PM
P-daddy's Avatar
P-daddy
Here are some pics of my C2 with HDs/M030 suspension. Hope they're helpful.
File Type: jpg
File Type: jpg
File Type: jpg
Old Sep 27, 2013 | 11:23 PM
zooming993's Avatar
zooming993
Very helpful, thank you.
Old Sep 28, 2013 | 05:45 AM
lopro's Avatar
lopro
cant wait to see the pics of the finished product when its back on all four.
looking good. Interesting info. My suspension research has begun, will change out this winter.
which jack stands are you using in this pic?
Great wheel well pics, have you refinished the red inside the well or is that OE?
If so what paint did you use?
Old Sep 28, 2013 | 08:31 AM
Beretta's Avatar
Beretta
Want to hear our reflection about the new setup, after you tested it for a few day´s.
About to upgrade my 95 as well.
I´m not looking to do race setup beacurse the roads here where I live is poor.
I want a good daily setup (spring and shocks) that can handle a handfull of trackdays each year.
I´m thinking to order Bilstein B8 and use H&R purple springs.
Old Sep 28, 2013 | 10:21 AM
P-daddy's Avatar
P-daddy
Got those jackstands from Griots Garage as a gift. They are ok. I feel like the 3 or 4 legged stands are more stable though. As for the wheel wells, that's all OE paint. I just use cleaner and an assortment of brushes to clean them up.
Old Sep 28, 2013 | 01:11 PM
techman1's Avatar
techman1
Picked up a set of stands like those from Northern Tool. Pretty well made.
