Help! - Car not accelerating or idling well after temp at replacing sparks and wir
Sorry to hear your problem but if you are running without the heater box you might want to plug the vacuum line sitting on top of he distributor. Vacuum is critical on these engines. I would also check the vacuum tee under the intake plenum, it might have pulled when you were routing the wires.
Here is an update video of the problem same thing... :/ Also i cant seem to find where this white clear hose goes. I think one goes to the right of the heat coil on the bottom left tube of the engine. but i dont know where the other goes if that could effect the car.
That appears to be the one that connects to the valve on the left side. That valve is attached to the plastic intake vent tube by two screws. Either plug it with a screw as a test or connect it.
I noticed that the Bosch and Beru have slightly different metal connection posts on their distributor caps. Both cap styles work well however if I use the Bosch cap I must use extra care to make sure the wires are fully seated.
Oh ok i see. Ya i don't know what the problem is, i've been just staring at my engine trying to figure it out.
Am i suppose to transfer a rubber guide from the old beru wires to the new? Thats the only thing i didn't do following the write up.
" The soft rubber guide has to be cut off the old wires & slid onto the new ones - a nice new, sharp single edge razor blade goes through it 'like buddah' "
~~ http://p-car.com/diy/sparkplugwire/
