993 Forum 1995-1998
Oil Cap Off...low idle?
Old Aug 22, 2013 | 12:06 AM
schubee's Avatar
schubee
Default Oil Cap Off...low idle?
I was checking my oil level today and noticed my idle (RPM's) did not decrease as I removed the oil cap. I remember this being true on my SC, Carrera and 964. Does this apply to 993's?
My idle is low (approximately 600) and does not stall. I do have a LWF and never experienced any stalling as well. When my AC is turned on, my idle does increase to where I feel the idle should be w/o it on.
I've checked vacuum leaks, hoses, etc... to confirm if I have a leak elsewhere. Car runs great and burns minimal oil. I have no CEL indicating any codes whatsoever!
So back to my original concern; should my idle drop when I remove the oil cap? Would this indicate a vacuum leak somewhere? Should I replace the oil cap?
Old Aug 22, 2013 | 09:34 AM
Quadcammer's Avatar
Quadcammer
no, it shouldn't.
my car idles low as well, but I believe thats because of a slightly inaccurate tach.
Old Aug 22, 2013 | 10:08 AM
swesna's Avatar
swesna
some times removing the oil cap would create a vacuum leak...not sure on 911s but know this is true for my Audi RS4. Even the dip stick gasket going bad on the RS4 can cause a vacuum leak.
Old Aug 22, 2013 | 10:46 AM
AOW162435's Avatar
AOW162435
Seared
I've never noticed a decreased idle when removing the cap.
Andreas
Old Aug 22, 2013 | 10:48 AM
Quadcammer's Avatar
Quadcammer
If the oil cap is on the engine itself (i.e. not a true dry sump), then the engine will breathe unmetered air through the crankcase ventilation system (a vacuum leak).
This is not the case on the 993.
Old Aug 22, 2013 | 12:38 PM
schubee's Avatar
schubee
I cleaned my ISV and even adjusted it a couple degrees.
However, as others mentioned here the ECU will just adjust it back to where the idle was prior.
The next thing I'll do is r&r caps and rotors, check plug wires and spark plugs.
Thanks for your comments!
