Clock (and adjuster button) stopped working...
Surprisingly, only found one thread on this in the archives. It points to a complete re-solder of the clock circuit board:
http://p-car.com/diy/clockrepair/
I don't have any warning lights coming on, which seem to accompany the clock stoppage -- my only symptom is that the clock and adjuster button stopped working for no apparent reason. The backlights work fine. Wondering if anyone has been through this and knows of a solution easier than re-soldering the circuit board, or whether this problem has a different cause entirely.
NP993,
I've removed and worked on several clocks. The lighting circuitry is separate from the movement. There are two root causes for the failure that I have come across, one being damaged solder pads that mount front mech and back pcb and the other being (depending on year) a miniature inline pcb fuse on the underside of the back pcb. Looks very much like a small diode. Continuity can be check with an ohmmeter on a DMM or DVM. If it's open, then just de-solder and replace with a standard fuse wire. Visually the front mech and back pcd looks as if it is just plugged together, this is not the case. The back pcb board can only be separated from the front half mechanism assembly by de-soldering the main feed pins (on the back pcb) which are hard mount points on the front of the clock. Solder wicking braid is best for this. Don't try to pry or force the back pcb from front as you will only damage the solder pads on the pcb. Hope that helps.
If you want, you can send it to me and I'll look at it.
Cheers,
Greg
Cheers,
Greg
Thanks Greg -- that's very interesting. I have a feeling it's going to turn out to be a problem with the fuse, as the problem showed up after I had removed and reinstalled the battery in my car -- figured it was just a coincidence, but perhaps not. I'll remove and investigate......appreciate your generous offer.
Cheers,
Greg
See pic.
Maybe you can help me out here with 2 questions: my clock was not functioning in the car (964); it also wasn't functioning when directly connected to a 12v battery. Any idea what the issue could be?
In the mean time, I also bought a reconditioned clock; it works when directly connected to 12v, but there's seems to be an issue in the car: the permanent 12v seems out of order. The #11 fuse in the luggage compartment works fine; so do the interior lights. Any other option than to follow the 12v wire to see where the problem is?
Also, on the big connector, what is the color of the wire connecting to pin #30?
This is a fun but frustrating project at the same time...
I'd be grateful for any guidance
