My first 993 diy oil change
#46
I didn't like the "pulling the fender liner out of the way" method as it abrades against the rolled edge of the fender. In time, that is hard on the paint.
Sure, to each their own, but there is a right way of doing things.
#47
I remove the oil line at the oil filter simply because it is easy to remove if done every oil change (or at least annually).
When I bought the car, that fitting was so stuck in place due to never having been removed (I didn't use the pry method). Like the dual distributor which can be a pain to extract due to the O-ring having "set"...same for that oil line.
#48
You certainly can and I did so the first time I changed the oil on my 993 (due to DIYs on the web), but have since always removed the rear wheel and front half of the fender liner when changing the oil reservoir oil filter.
#49
Cheers,
Mike
#50
Regardless, I usually remove the wheel just because its easy on the lift, the and the car is in the air anyways. i was just pointing out it's possible to do this with the wheel on, and do it with relatively no damaging components. It is a more cramped method for sure though.
I suspect this will be a long thread ...
Cheers,
Mike
#52
somebody needs to invent a disconnect one pipe, attach pump flush system....
#53
It ain't the complications of getting the oil out, but it's getting to the filters.
Porsche Engineering reach the zenith of anti-ergonomic design by hiding one oil filter under the rocker panel and the other deep inside the engine surrounded by the engine, suspension components, air heater tubes, and hard oil lines!!!
And people says the placement of switches (sunroof for example) is bad. They should try to change the 993 oil + filters.
Wait...there is one better....the upper cyl 6 sparkplug! (Well, at least they provided an access panel entry)
#55
Cheers,
Mike
#56
--Michael
#57
button queen
You know, it's been awhile since I did it the one time I had to. I am talking about reinserting the oil line that runs under the smaller filter. Seems I recall having to use a threaded coupling (and to massage the rubber portion further up the line) to get it back on.
#58
Sorry no pic of my own.
#59
form-a-funnel I used last time. Made a big difference is the amount of
spillage (almost none). I held the funnel with my left hand while removing
the drain plug with the right as I wasn't sure the funnel would stay in place.
I change those o-rings each time. Now since I bought the Molykote 55 to
install the lower valve cover gaskets, I'm using the o-ring grease to lube the
oil tube o-rings and the filter gaskets instead of motor oil.
The o-rings shown here are green and were on the car when I got it.
All the ones I've installed have been black I think.
-bruce
Last edited by bruce7; 07-26-2013 at 07:27 PM. Reason: added comment about o-ring colors
#60
I was thinking of getting one, but then came across many reports of them de-laminating...the plastic covering coming off the lead sheet.
