Immobilizer issue HELP!
No prob, thought maybe I had missed something.
When the immob works, it works quite well.
Do as the others say....turn on the ignition, hit the fob button and indicator lights will flash. Turn off then turn the key, start and enjoy the ride!
Just as an update from my post in July, had the same issue today and discovered that the fob battery was down to 10.5 volts. Bought a new battery (12.67v reading), re-connected the car's battery, and was able to click the fob to stop sounding the horn. The red LED on the fob didn't initially light up when the button was pressed, which adding some tension to the contact strips fixed.
