993 Forum 1995-1998
Powerfull headlights
Old Jun 5, 2013 | 03:30 PM
c4consult's Avatar
c4consult
Default Powerfull headlights
Please tell me what are the most powerfull headlights I can install in my 1997 993 C2S.
I live waaaay out in the country in Tx.
Thank you all.
Old Jun 5, 2013 | 03:35 PM
LexVan's Avatar
LexVan
Probably a litronics kit, if you don't already have the factory option.
Old Jun 5, 2013 | 03:38 PM
mike cap's Avatar
mike cap
I would suggest converting to a GE aircraft landing light.....
File Type: jpg
Old Jun 5, 2013 | 03:49 PM
c4consult's Avatar
c4consult
Mike........what size aircraft?
Old Jun 5, 2013 | 03:53 PM
c4consult's Avatar
c4consult
I do not have the litonics.
Is that what you suggest?
Old Jun 5, 2013 | 04:42 PM
kjr914's Avatar
kjr914
Search here for HID, which is WAY cheaper than factory Litronics. Also see:
http://www.pcarworkshop.com/index.php/993_-_HID_Lights
http://p-car.com/diy/aftermarkethid/
A rennlister is supplying a kit with matching fogs....scroll down on this page:
http://www.bergvillfx.com/products.html
Old Jun 5, 2013 | 04:45 PM
c4consult's Avatar
c4consult
Thank you for you help, kjr914.
Old Jun 5, 2013 | 04:58 PM
P-daddy's Avatar
P-daddy
If HID conversion isn't enough, you can do HID fogs in addition to the lows.
Old Jun 5, 2013 | 05:01 PM
boman993's Avatar
boman993
Installing aftermarket HIDs was one of the best mods I've done on my 993!!! The halogens are useless in the dark!
Old Jun 5, 2013 | 05:07 PM
mike cap's Avatar
mike cap
Just joking....although I did install a set in my 1967 Corvette way back when. Wow !!
Old Jun 5, 2013 | 05:11 PM
EMBPilot's Avatar
EMBPilot
These don't work that good
Old Jun 5, 2013 | 05:23 PM
axl911's Avatar
axl911
Aftermarket HID with the 55W bulbs!!!!
My HID low beam is just as bright as the standard bulb high beam. Just make sure your headlighs are aimed properly!!!
Old Jun 5, 2013 | 05:28 PM
mike cap's Avatar
mike cap
Well, true, there MAY have been some burnt wiring and blown fuse issues. But man, did they light up the road (for a short time).
pp000830's Avatar
pp000830
Use care, really bright headlights will blind drivers in the facing lane. I found that when I upgraded to high energy discharge lamps I had to set the pattern a little below the DOT specification otherwise drivers kept flashing me to turn my high beams down.
Old Jun 5, 2013 | 05:58 PM
Van Larson's Avatar
Van Larson
Default Landing light
De ja vu again. I had a single 5 " ge landing light on pass. Hi beam on a 77. 320i. If left on for more than 30 seconds, it started to melt the surrounding grille. But while functioning and in use, it was to say spectacular.
