Brake pads n spiders n $'s ?
Can someone please post a picture of a 993 brake spider, that half of you guys recommend to leave out when changing pads?
Is a spider what is aka a vibe dampner?
Does $420 for pads on all 4 corners (less shoes for E brake) + sensors, + vibration dampners, sound like a good price for Textar pads?
If not, recommendations please for where to purchase?
Thank you gentlemen
Thank you gentlemen
I learned the hard way. I first bought Pagid "OEM formula" pads, then Mintex and finally porsche OEM from sunset. Porsche OEMs are the only ones that don't squeal like crazy.
The spiders are the circular vibration dampers that stick to the backing plate of the pad. I left them out and with porsche OEMs, no squealing.
If you're worried about squeeking, go with Porsche oem. I went with aftermarket on my first 993 with no spiders, and had no squeeking at all. Brake pad DIY is a very easy job. I've done a few of these pad changes. First timers may take 45-60 min per wheel including jacking and wheel removal. If you ditch the spiders, changing pads becomes a snap!
If you start "cleaning", then you will be there all day. It is amazing what you see with the car off the ground, wheels off, and sitting on the ground.
This and an oil change is a great way to learn about your car.
Yes. Depends, once you have done it a few times (Track swap for example), can be done in under 10min a wheel. First time, take your time, look around the wheel well and admire the great German Engineering, plan on 1/2 a weekend day.
Thank you gentlemen
Thank you gentlemen
I always use the spiders on my pads to reduce squeal.
I also nearly ALWAYS but my stuff from Tom or Bev Gould @ TCs garage in Vista
http://www.tcsgarage.com/contact.asp
Great people, Great service, fair prices.
Bev is the current SDR PCA president.
Cheers
Craig
Craig,
Thank you for the photo...A picture is really worth a thousand words.
I read quite a few threads on recommendations for brake pads for 993 and the concensus was Textar or Porsche OEM; unless you're tracking, DE'g, or AX'g regularly.
BTW, the quote of $420 was from Sunset, which is why I was pulsing the crowd
When comparing pad pricing, is a set considered two pads for each caliper, or 4 pads for two calipers? (i.e,; two fronts calipers)
Basic Sponsor
We offer OE pads (Textar) and are local to you so you'll receive them the following day after ordering:
993 Pads
Let us know if you have any questions - 888.280.7799
Mark/Pelican Parts
993 Pads
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Technical Guru
993 Pads
Mark/Pelican Parts
993 Pads
Mark/Pelican Parts
Those OEM Textar pads are not the same compound as the OE pads. One squeaks and the other doesn't!
Craig,
