oil temp
Had time to sort this over the past few days with a lot of driving in different conditions. Ambient temps have been right about 80 degrees. Oil thermostat is working fine. My fan kicked on low just over the 9 o'clock position shown in pic below and just as described in the DIY on p-car. Temp lowered a bit from there but during slow driving and a lot of idling it will raise just above the 9o'clock and never goes higher. I'd like it to run a bit cooler but based on everything I've read I'd say its pretty consistent with normal operation. I'm feeling better now.
Thanks to all who have chimed in with suggestions and comments. You guys rule!
Received 5,411 Likes
What oil (brand and viscosity) are you running?
