Just picked up a 3rd brake light - I have a 1995 993
Will the wires already be there tucked under the rubber that runs around back window? Or will I have to run a set of wires myself? Been trying to find any diagrams I possible could but no luck
The followng Technical Bulletin dated March 7, 1967 may be helpful. I can email the bulletin to you if you can't find it.
Service Installation of Roof Mounted
Third Brake Light
Part Identifier
6638
Number
9603
Third Brake Light
Part Identifier
6638
Number
9603
Third Brake Light
Part Identifier
6638
Number
9603
Gotta like the way Porsche is always thinking way ahead! In this case 46 years Originally Posted by Porsche70T
The followng Technical Bulletin dated March 7, 1967 may be helpful. I can email the bulletin to you if you can't find it.Service Installation of Roof Mounted
Third Brake Light
Part Identifier
6638
Number
9603
pp000830
close
- Join DateJul 2004
- LocationDallas, TX
Liked:2,049 Times in 1,414 Posts
Sometimes the wires are bad due to corrosion and vibration where they go through the glass.
If this is the case Search for this old post on how to diagnose and fix;
"993 High mounted Cyclops light wire fix"
Andy
Andy
