225/40/18 or 235/40/18 Sumi IIIs on 8" BBS LMs?
Hello Guys,
As the title states should I get a set of 225/40/18 or 235/40/18 Sumi IIIs for my front 8" BBS LMs? For the back 11" LMs I'm getting 295/30/18. I'm at RS+10 height on PSS9s with all other suspension components being stock.
Thanks!
Martin
Thanks!
Martin
I've run 235 on the front before with no issue, but not all 235's are created the same. The car handling was much improved (less understeer). I'm at RS +10 also, so you're likely to be fine.
