993 Forum 1995-1998
Becker cdr220 faceplate too dim
Old 01-11-2018, 01:08 AM
Jlaa
Jlaa's Avatar
Originally Posted by tcsracing1
I just installed the CDR in my 964 turbo. Screen is too hard too read.
I did this mod to my 993 a few years ago but my screen is easy to read.
Who is modifing these or selling the modded face?
Contact Jim Corenman ---- noted in the thread referenced in post #5. His modifications work really well.
Old 01-11-2018, 02:26 AM
Rick-A-Shay
Rick-A-Shay's Avatar
Sent my "CDR220 Controller" (faceplate) to SWStereo Specialists. Display was missing some letter "segments". $148 and new fresh display but different color........ Quick turnaround. Some may know of cheaper solution?
Old 09-23-2018, 06:25 PM
tcsracing1
tcsracing1's Avatar
how do you remove the faceplate?
Old 09-23-2018, 06:27 PM
Jlaa
Jlaa's Avatar
push the "release faceplate button" on the top right, then just pull it out of the electrical contact holder thing by pulling up and out.
Old 07-25-2021, 05:19 PM
Elli
3rd Gear
Elli's Avatar
Default Help needed radio face plate dim
recently I changed the battery in 2002 Boxster, the asked for a code but I did not insert the code. The car was not used for about one month now the face plate is very dim and does not ask for a code numbers.. help please!!
Old 07-27-2021, 03:44 PM
Jlaa
Jlaa's Avatar
Try swapping faceplates or entire radios. What happens?
Old 07-27-2021, 04:09 PM
Elli
3rd Gear
Elli's Avatar
Default Face plate not removable
thanks for the prompt reply, my mechanic says the face plate is not removable ? CDR 220
Old 07-27-2021, 04:28 PM
Jlaa
Jlaa's Avatar
He is misinformed. Rotate it down and pull it straight out. Regardless, I suggest you start a new thread as “my radio does not operate” is a different issue than the original purpose of this thread, which was “how to make the faceplate brighter?”
Old 07-27-2021, 04:31 PM
Elli
3rd Gear
Elli's Avatar
He is misinformed.
how do you remove the face plate? I tried and did not want to force it?
Quick Reply: Becker cdr220 faceplate too dim
