Jack stands?
Not only that, the more distance and objects put between the car and the jack stand, the less stable the setup.
The only exception I can think of that would be more stable; is the machined inserts that locate in the jack point holes, coupled with esco jackstands, which would provide a round flat against flat surface. A round 1/8" piece of rubber between the insert and the stand couldn't hurt, by prohibiting any sliding of metal against metal...If the esco stands have a piece of rubber glued to a recess in their flat, then the rubber piece I mentioned is not needed. Bottom line is all this costs $$$, and since I manage just fine with my stands, which look like those in the photo; I take the rest with a grain of salt.
To me, the esco's may be for those with more $$$ than sense.
Kudo's to the guys that can spend that kind of scratch on jack stands and never give it a second thought. I just dont happen to be one of them.
I concur...Bruce knows his stuff, but in this respect, I disagree. You will notice that the RL 993 group sometimes gets a tad over the top; like when protecting the jack points on the bottom of the car from marring.
Your jack stands will work just fine. There is ABSOLUTELY no reason to spend that kind of money on stands; especially if you already have a set.
towing tie-down. My two front jack points are like that, no flat metal surface
any more. To fix them a body shop estimated $1500.
pmartinslx (10-08-2020)
Thanks guys. I'm not too worried about marring my jack points. I could just wrap a shop rag or something over the top of the jack stand. Lucky for me my jack points look excellent. I just want to make sure that the car is stable when I replace the lower valve gaskets. I'll likely keep an eye out for some round top ones on sale in the future.
Thanks.
Thanks.
I have no concern whatsoever about marring the jack points, I do however have concerns about crushing the underbody plastic panels around the jack points, hence the hockey pucks. As for the setup in the photos at top my concern would be that the car would shift/slide when you're jacking up the other end of the car (as the weight/position) is shifting (and also being under the car during an earthquake but that's a whole 'nuther discussion...).
I've had my Esco's for several years, actually think I got them during one of our RL group buys. They are a tool, I could have bought cheaper tools but these particular tools are worth the premium I paid for them (to me).
Just my .02
Just my .02
I would not get under a car w a hockey puck between it and the V Style jack stands. Ur life depends on it. I'd just drop the car onto the stands w/o the puck if ur ok making ur lift points gnarly.
I love my escos though.
I built these years ago... very positive lock to the top of the jackstand and the engine motor mount. I did not want the car to slip off the jackstand. There is a pin that locks this to the top of the stands, and then another pin that goes inside the hole on the car's mount.
The pin is positive locking, another variant of the locking ring with magnets attached.
Cheers,
Mike
Cheers,
Mike
I ordered a set of these metal pucks from Ebay - looked just the job for the top of my escos.
When they arrived they were ridiculously small at 4 cm. diameter.................I would never use them and sent them back.
Here is what I went with. A little less expensive, but I like the flat top that has a little bit of pivot to it. Not the tallest...so while doing the engine removal I have several blocks of wood under it. But i think these jacks will be great for something quick.
http://www.northerntool.com/shop/too...8899_200318899
I seen something like that at my local Canadian tire. I don't want to mark the jack points as I'm kind of **** retentive. I'm sure I'll figure something out. I just don't want to F the car or myself up in the precess.
Cheers,
Mike
Cheers,
Mike
The main thing is we all agree we don't want to die under our cars.
When I last had my car jacked up on all four a friend stopped by and admired my esco's and the other precautions I was taking - wheels under car etc. He recited a death by falling car story that could have been him. Scary stuff. What a way to go....
More like it was a bit of fun ...however I would always keep a jack or two under the car even with the jackstands as a double safety thing.... like my large floor jack under the centerline of the engine, or I have a pair that can be used on each side of the front on the suspension mounts....
cheers,
Mike
cheers,
Mike
There are many comments about these on Rennlist if you search the site. Plenty to read while you're making your decision. Whichever way you decide to go, pick the method that you're comfortable will protect you and your car. Working with your car in the air is a bit like being on the track - if things go wrong they go wrong fast. And the damage will generally be greater than the savings.
