Stripped Rear Control Arm Spindle Shaft
Hello Guys,
I managed to strip the rear control arm spindle shaft so now I'm kind of hopped. I was able to get the control arm off the car by cutting the bolt off with a dremel and cutoff wheel but that almost meant that I damaged the treads on the spindle shaft.
Is there a way to replace just the spindle shaft or do I need to fork out the cash for a brand new control arm?
Thanks,
Martin
Thanks,
Martin
It's the rear lower control arm, the one that attaches through the bottom of the shock and then to the eccentric bolt by the sway bar mount. Does that make sense?
It's #3 in this pic.
