Headlight/foglight protective film
Can anyone comment on the precut Lamin-X Protective Film Headlight Covers Porsche 993?
Ease of installation?
Quality of product?
Protection qualities of the film?
Thanks so much in advance, gentlemen
Quality of product?
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
I got it a long time ago. It's pretty easy to apply, but as you put it on it will stretch and deform slightly. not a huge deal, but it you're über-**** retentive about your headlight film, it could be a problem.
The instructions say that you should use barely any water when you apply because it will hinder the bonding abilities of the film. Well, I did it exactly as they said for my E39 (three squirts of water from a spritz pump) and the film stuck too early and when i tried to reposition, the glue pulled off and the film was ruined. I got another set (at 1/2 off from Lamin-X (still a rip off)), and this time I saturated the headlight lens with water and applied. I was able to reposition and get it right this time. The film has had no "bonding" issues at all and is indeed perfect. Hopefully this info will prevent someone else from having as frustrating an experience as I did that first time!
I recently ordered a set for headlights & fogs from FDM. Haven't applied them yet but I'm sure they'll be fine. Can't go wrong for $40. http://fdmotorsports.net/993-headlig...ens-protection
headlghtarmor.com is the best
Ive used laminex or lameX - many freinds have tried others with little results but headlight armor is amazing.
I have some film new in package forsale 50 shipped. GT yellow film.
I bought/installed the Pre-Cut kit from Lamin-X about 6-7 months ago and thought it was "okay". I think the film itself is a high quality product and it arrived at my door pretty quickly. It's easy to install at long as you use a generous amount of the alcohol/water solution to ease positioning. Squeegee it all out and you won't have any issue with it adhering from now until the apocalypse! They only downside I had was that the "pre-cut" part of the product left a little to be desired. It was not a direct fit and I had to do some trimming after they were installed. Really not a big deal because it's pretty easy to cut with a sharp razor, but I found myself wondering why I needed to trim it at all.
Ed,
You think Xpel is the best based upon what first hand knowledge, work, or testing of the vasious products on the market?
From what I currently understand there is 3M, Xpel, and Lamin-x products. Precut prices range from $40 Lamin-x - $55 Xpel.
Can you please provide a basis for your comment on Xpel, as it sounds like you have first hand knowledge about the various products.
Thank you for the sharing of your knowledge with the others that may be wondering the same.
I agree with Ed. I also installed xpel and in my opinion it is a quality product in material and pre-cut shape is perfect. I put mine on about 4 years ago and they still look new. DIY video is on the website and a install tool is included. Good luck on your search.
Yes, my knowledge is first hand, based on very expensive H1's on my 911, and sort of expensive lenses on my 993. Cut has been perfect, and the alcohol mix, a squeegee and a hair dryer make quick work of installation. No issues with extra trimming or the material not laying flat.
Nothing left to search here...
I agree completely with your most comprehensive response. Thank you for thaking the extra time to provide a basis for your initial response.
Based upon the info you provided, I will be going with the Xpel due to their quality, ease of application and fitment.
Thanks to all RListers who responded!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
