update: new wheels-Rotiform/BBS
#46
Hi, big rig. How about reverse-mounting BBS LM099/LM100 8 and 10 x 18s with 225/40 and 265/35 Rosso N4s? Estimated net offsets (assuming 15-mm decreases from reverse mounting) would be 41 and 50 mm for the 8 and 10 wide, LM099/LM100, respectively. This isn't too different in set up than my current 8/10 wide Fikse FM-10 in 51/57 offset with the same sized Rosso N4s? The wheels/tires will move 0.4 inches outboard in front, and 0.3 inches outboard in back? http://www.rimsntires.com/specspro.jsp
what suspension are you on?
#52
FYI, BBS USA doesn't recommend reverse-mounting their LMs, as the entire wheel load is carried by the assembly bolts, rather than the mating surfaces between wheel center, rim flange, and wheel bolts. Reverse-mounting LM wheels if the centers were not designed to mate properly will lead to wheel failure.
Also I wonder what BBS Japan's take is...
Some fitments avail via BBS Japan isn't available via BBS USA FWIW.
#54
#57
#58
how can i help?
is there any specific question i can answer?
![](https://farm8.staticflickr.com/7537/15187252144_f3832090eb_c.jpg)
![](https://farm8.staticflickr.com/7461/15621390199_2049071768_c.jpg)
#59
Step 1, obtain 60-65et 11" wheels.
Step 2, put narrow treadwidth 285/30 or 275/35 tires on them.
Step 3, dial camber in rear to at least neg 2.5 degrees.
Step 3.5, If required, roll fender lip upwards into fender with heatgun and that fender roller with the ECS adapter mentioned below.
Step 4, enjoy 11" wheels on NB 993.
ECS sells an adapter: http://www.ecstuning.com/Porsche-199...ler/ES2702755/
