ok , neo is blazed with the red pill..pss10 adjust meant
i got pss 10...
the car settle tonight 24.8 inches form the wheel arch in the front
and 24.9 in the back...
when i started it was 26.75 and 26 in the back..
i think the car is too low.
1) WHAT IS A GOOD RIDE HIEGHT? I WAS THINKING 25.75 IN FRONT AND ABOUT 25 IN THE BACK..
2) at number 6 on pss 10 i felt that my kidney would fall out at each bump..for street 3 maybe?
3) the bilstein manual says 20mm travel adjustment..so i am gonna max it out in the Am..
any suggestion would help...
thanks
Lemon
thanks
Lemon
i got pss 10...
thanks
Lemon
thanks
Lemon
I'm sure there is a sweet spot just prior to encountering bump steer, or do the drop links address bump steer?
BTW, "adjustment" is one word
nine 9 six....its called ipad spell check.. and i hate it...we missed you this am..
anyways..update this am...
i think the car was tab bit low...the suspension settled at 24.5...wich was the worse ride ...no play on the pss10...
so this was the pic ...before the get together this 6:45 am..
Lemon
Lemon
Lemon
Lemon
Would you be so kind as to post your final height settings?
I WILL make the next one!
