OIL FILTERS
Gotta run, otherwise I would look that thread up for you.
Cheers,
Mike
Because humans aren't the sharpest tools in the shed.
They'd ask what the best oil to get is and then ask whats the cheapest oil filter they can get.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
I'll buy the OE Mahle filter on the top and they'd buy the Fram on the bottom. These are for the same vehicle.
![](http://edelweiss.smugmug.com/Motorcycles/Other-Stuff/Odds-n-Ends/i-8Q6B3dN/0/M/BMW%20Open-M.jpg)
![](http://edelweiss.smugmug.com/Motorcycles/Other-Stuff/Odds-n-Ends/i-Fs3snNz/0/M/FRAM%20Open-M.jpg)
Mahle filters seem to be superior to the Porsche factory ones, but ONLY the Porsche filters work properly on the Turbos. For an NA car, the Mahle filters are the way to go.
The conclusion of that thread was mixed although it tended to favor Mann over Porsche for NA cars because of the pleat count and pressure value, and the Porsche filter is a must have for the Turbo. I have a Turbo, so of course will stick to Porsche brand.
Here is a thought - if the Mann filter does not have a check valve, and given its position in height on the engine, its it possible that some oil may drain or be siphoned from the filter when the car is stopped, even on a non-turbo car? That may mean you are starting the car up every time with a slight delay as the filter circuits fill up before the oil is fully pressurized in the engine? That would take some experimentation, I do know the small oil filter will dump oil similar to being overfilled when changing, but that may not mean all the oil that should be there is.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Highest wear is on startup as wel know, so that alone would make me want to stick to Porsche only.... not sure how to test for it though.
Cheers
Mike
