Low speed clunking/knocking after PSS9 Install
I got the same issue, after installed the Bilstern HD with M030 spring, clunking sound from the driver side front wheel area at low speeds. also no feel or vibration, just a sound when turning at lower speed and straightening out. seems the sound from the spring with seat. any idea to solve it.
get the spring kit i posted..
Open the hood, remove carpet, and tighten the M14 or 19mm top nut of the shock to torque. If it is tightened to torque, tighten a tad more. (5 minutes on a watch)
and give $75 to rennwish or an NGO of your choice.
regards
Can you post the photo of spring kit and where can get it, i would like to make a trial. ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Are any of you guys experiencing this "clunk" noise when driving over a speed bump...or just when you are turning slowly then straightening out? I got the clunk noise after pss9 install in Portland, OR... mentioned it to the installer but they dismissed it as probably something loose inside the boot. Very knowlegable guys, so??? Mine especially clunks going over speed bumps. I dislike the noise but have lived with it now for years.
