993 Forum 1995-1998
Brake reservoir questions...
Old 03-04-2013, 05:58 PM
BradB
BradB's Avatar
Default Brake reservoir questions...
I am in the process of flushing my brake/clutch fluids and had a few questions.
1. What does the white insert in the top of the reservoir actually do?
2. How do you remove the white insert?
3. The reservoir has compartments, but they have to be connected somehow. Where? Only at the top somewhere where they overflow into each other? Or can the fluid intermingle elsewhere eventually via weep holes? I ask because I am having a dickens of a time with remnants of old ATE Super Blue colorizing the new Gold I am adding. It seems to creep from compartment to compartment. (Except the clutch which has remained Gold.)
By the way, one culprit that held lots of ATE Blue was the accumulator. I bled that today and it seemed to clear up most of the forward compartment. But now the larger two rear compartments, which were at one point clear Gold, are turning Blue-er. Arrrgh! I have gone through THREE CANS of ATE so far!
4. I understand that, when fluid is removed from the reservoir, the clutch is the first to suck air. And I see the clutch hose attached at the rear. So that means I can safely manually suck out over 3/4 of the fluid out of the reservoir itself? Right? Are there any marks or indications on the reservoir to go by? I've turkey-baster'd out some fluid but am afraid to go too far.
I wish I could see a cross section of the reservoir.
Thanks for any input.
Old 03-04-2013, 09:54 PM
Slow Guy
Slow Guy's Avatar
The insert usually just slides up/out but that one doesn't look original, the slots appear to be too big.
I believe the intention of the insert is to keep your brake fluid "dipstick" at a fairly constant level when you're driving like a maniac. Fluid flows in/out of the insert but rather slowly. Yours however, the slots are far too big (IMHO) and it would reduce the effectiveness of the insert.
Now maybe that insert is from a different series car but I've had a '88 911, '93 968 and a couple of 993's and none looked like that.
Old 03-04-2013, 10:19 PM
IXLR8
IXLR8's Avatar
Brad,
When I did a complete flush of my brake and clutch system, I removed my brake fluid reservoir and flushed it out completely.
Have a look at the pics of the reservoir and note how the plastic lines are held in place. The instructions under the pic tell you how to release them. See pic #15.
The clutch hose will need an Oetiker stepless ear clamp if you want to keep it original.
Old 03-04-2013, 10:28 PM
cgfen
cgfen's Avatar
1. to annoy you / me or to accurately locate the fluid level float
2. i remove it with needle nose pliers by rotating and pulling when i do a fluid flush
3. i think connection is only at the top of the reservoir chambers. it usually takes me 2 full quarts of fluid when "changing colors". Suck as much out as possible first using a "turkey baster" or similar tool. The rear reservoir chambers seem to be the last to evacuate. drain as muc as possible using bleeders aslo.
4. yes / no / too many variables.
my last flush was the first time i've gone from blue to gold with only 2 quarts. other tries have taken 3+.
it was also the first time that i bled the accumulator 4 times prior to working on any of the other chambers.
coincidence?
i don't think so.
good luck
Craig
Old 03-04-2013, 11:51 PM
BradB
BradB's Avatar
Thanks for the replies, guys. Quite helpful.
My plan now is to siphon as much Blue as I can out of the top of the reservoir and then re-bleed everything again. I'm determined to remove all traces of Blue!
Next time I will bleed the accumulator FIRST! Lessons learned.
As far as the white guide for the plunger, it's been there the 11 years I've owned the car and never had an issue. If it was replaced at some time it's hard to imagine why. Who knows.
Old 03-05-2013, 12:53 AM
TheOtherEric
TheOtherEric's Avatar
What is an accumulator, and how do you bleed it? I can't believe I'm not understanding this.
Old 03-05-2013, 02:34 AM
kjr914
kjr914's Avatar
The C4S/Turbo brake pressure accumulator. The round black ball in the front trunk hiding just in front of the gas tank on passenger (USA,EU,etc) side. IIRC, it stores up pressure for use when the ABS/ABD kicks on. I'm not familiar with the C2 system, so I don't know all the differences...
Old 03-05-2013, 08:04 AM
Falcondrivr
Falcondrivr's Avatar
I used the super blue for a while. I think it took three or four complete flushes to stop seeing a little green color. The solution is to start going to the track a lot so you will be flushing your brakes several times a year!
Old 03-05-2013, 09:39 AM
TheOtherEric
Ah, thanks. C2 doesn't have that afaik.
Old 03-05-2013, 12:12 PM
Slow Guy
Slow Guy's Avatar
Any body else insert look like Brad's?
Old 03-05-2013, 12:16 PM
BradB
BradB's Avatar
Last time I heard that was in my high school locker room.
Old 03-05-2013, 01:41 PM
Kein_Ersatz
Kein_Ersatz's Avatar
I surmised the insert tube was there to prevent drastic changes in the fluid level with the float as the car shifted under aggressive driving. Which in turn prevents a false reading on the fluid level.
And it is a pain to add fluid in it as it chokes the filling speed of the reservoir with the sleeve in.
Old 03-05-2013, 08:18 PM
e9stibi
e9stibi's Avatar
Exactly what my 4S has.
Old 03-05-2013, 08:26 PM
mhm993
mhm993's Avatar
That little cup is some engineer's joke to make sure you drip brake fluid everywhere when power bleeding. He laughs every time we go near our cars with a can of blue. I swear I can hear him faintly in my garage.
Old 03-05-2013, 09:08 PM
kjr914
kjr914's Avatar
+2
Only mine doesn't seem to come out easily like Craig's does....
Perhaps more force is needed (a statement that never leads to good things)...
Quick Reply: Brake reservoir questions...
