Strange sound from rebuilt engine...
#332
I didn't think anything serious of the oil pressure due to the fact it was stated as a top end job. Yeah rod/crank bearing tolerances play a major roll in oil pressure. I'm sorry to see this.
#333
First off, BRAVO for tackling something like this yourself. Someone smarter than I said "You learn more from failure than from success."
To illustrate, I just helped ZombiePorsche44 through a flawless R&R of belts, fan bearing, and alternator in an afternoon.....using my knowledge of my 3x alternator rebuild over 2 months due to my own error on install round 1. Application of the BFH and alternator removal are NOT compatible...who knew... Oh, not to mention snapping 2 new belts due to a rag left on the bumper that was sucked into the fan... Oh, and I need another full rebuilt alternator, since the thing STILL isn't right.
You are not alone my friend.
^^^^THIS...is why I am here. Good people.
#334
Because of the debris in the the oil stream, I think the only option forward is to split the case and do a complete cleaning, otherwise there is a risk of other pieces of debris in the system somewhere than can ruin any number of components, including bearings, pumpt, etc. He will need to split the case anyways to get the crank checked and cleaned, and then build it up from there. Steve mentioned that as well previously. The good news is that it will be a complete rebuild which should last many years.
Again, Peter, take heart, we are all behind you!
Cheers,
Mike
#335
Check the rod bolts' end from the video...The nuts rhyme and are not loose.
This video shows how these engines are tough. Whatever the reason, with such play in the rods, the engine ran and ran.
The rods being loose, the engine case got filled up with oil from the crankshaft.
Hopefully you have the bearings inside, and that the rods are wrong. Lets hope the crankshaft is fine.
The challenge is to remedy with the least cost.
#337
And my first worry would be to rebuild with the least cost since I do not have funds these days
#339
Peter I am glad you avoided the take it out and run it hard to pump up the lifters. That would have left you with a pile of metal. Sounds like the bearings may not be on the rods. I have an extra 993 crank that was machined/ magnaflux'd at Ollies if it turns out you need one.
#341
BTW, you have to split the case. If the rods were hitting the cylinders then it is likely the oil pump has been hit also. Clearance on the pump is really tight eg Carillo rods require machining of the pump itself. Bummer, but it absolutely could have been worse.
#342
MEA CULPA! MEA CULPA! No. Bearings. MEA CULPA!
I offer this with tongue in cheek: Confiteor
Confiteor Deo omnipotenti, et vobis fratres, quia peccavi nimis cogitatione, verbo, opere et omissione: mea culpa, mea culpa, mea maxima culpa. Ideo precor beatam Mariam semper Virginem, omnes Angelos et Sanctos, et vos, fratres, orare pro me ad Dominum Deum nostrum.
#345
RL Technical Advisor
I knew a fella who did the same thing in a Ford marine diesel. Bloody thing already made so much noise that you couldn't hear anything odd, but he noted that the oil pressure was low for a rebuilt engine and that was the giveaway.
After a VERY thorough cleaning and a replacement of the rods & crank, everything turned out fine.
