Question: Turbo S Ducts with Lights
I need to get up to speed on this for next years mods ... the procedure below is to add upgraded lights to third party ducts (I think they were Marks, not sure). Anyways, since I did this years ago, HID technologies have come a long way, so I am sure there are better lights, but I did like the pattern on these lights, and they were really well built.
As documented in pcarworkshop:
http://www.pcarworkshop.com/index.ph...lla_Fog_Lights
Light Assembly
![](http://www.pcarworkshop.com/images/f/fc/060708_0060_small.jpg)
After some work (see article).
![](http://www.pcarworkshop.com/images/9/95/060708_0088_small.jpg)
Final pattern
![](http://www.pcarworkshop.com/images/1/1e/060708_0096_small.jpg)
Light Assembly
Final pattern
Thanks for the great detailed DIY with nice pictures.
If you were to change your fogs to HID's, then you should match them to the shade (degrees Kelvin) of your low beam HID's. I wouldn't change out just the fogs to HID's without upgrading your primary lamps.
Not only is this Hella lamp more robust that the knock-off halogen lamps out there (i.e. water resistant and built better), but it's bulb can be replaced by an HID equivalent as a mere plug-n-play swap.
