Installation thread for KONI FSD suspension - UPDATE #1
#121
#122
Thanks for the first hand FSD-993 feedback. I'm following suit as a winter project. Our 993 coupe was fitted with the M033 spring set many years and miles ago; 2001. Ringing Gert at www.carnewal.com as we speak. Thanks again.
PS. I have 2 new LED bulbs (sourced from Gert) for the front parking lights as fitted to the Euro factory bumper/fog light assemblies lens. The bulbs are free to good home. First PM is a winner. These work just fine and appear similar to the factory Litronic HID lights when lit, just not my cup of tea. Update: There GONE to a Rennlist'r
#125
Just wanted to say this was a helpful thread as I just went thru my suspension for the first time. My stock Monroes were gone and I was getting a shimmy in the steering wheel due to worn control arm bushings. I did not go with the Koni FSD but went with the Koni Sports instead. My primary reason for this was that I wanted to retain my H&R lowering springs because I really like the stance. The Sports were recommended for lowering springs. Here is what I ended up doing on my car:
Koni Sports with H&R lowering springs
Walrod bushings in the front control arms (installed by Andreas)
Replaced one front drop link due to wear (stock Porsche)
Replaced both rear drop links due to wear (OEM)
Replaced both rear lower/toe control arms (stock Porsche)
Replaced the front strut bump stops as they were disintegrated (stock Porsche)
Replaced the plastic clips holding the brake sensors as they broke when removed (Porsche)
Have an appointment to have the car aligned at Johnson's in Torrance on Monday. Will report back once I have a chance to drive and experience the new set up.
New parts! Early Christmas gift to myself.
Control arms came back beautiful after Andreas installed the Walrods and bead blasted them!
#127
Today was alignment day. As promised, I am reporting back. Took the car to Johnson's to have Steve do the alignment. Before we get to my car, here are some photos of not 1 but 3 959's next door at Callas.
Okay, back to my car. This suspension refresh may be the best thing I have done to this car over this past year of ownership. Just to show how important it is to take these cars to someone who knows how to align them - Steve was dumbfounded with "whatever the prior idiot did" when they aligned my car. My car had H&R lowering springs on it but with stock Monroes. It looks like when the prior owner installed the lowering springs, the alignment was really messed up in the rear. It took Steve quite a bit of time to reset all of the bad adjustments that were done (something about adjustment up top that were pushed way out).
Anyway, here is the report on my set up. All I can say is wow. I cannot believe I am driving the same car. Thanks to the Walrods, the shimmy in the steering wheel is completely gone. Everything is now incredibly taut and responsive. This past year of driving on worn Monroes with a bad alignment and other worn suspension parts is now gone and I feel this car has been reborn! I am very impressed with the Koni sports. They are taut yet very compliant over bumps and in fact a bit softer than I expected. They are currently set on the softest setting, so I have plenty of range to tighten them up if I choose to. I chose the Konis because I wanted something close to stock sport and that would work well with lowering springs (I like the H&R stance). I also wanted something that looked fairly stock. The Konis look almost identical to the stock Monroes except they are yellow instead of green. I do not track this car so the better performance of Bilstein wasn't needed for me. The investment of time and money in this project was worth it.
Here is a shot of my car with Steve aligning it. I love the stance!
There was one casualty in this project. My teenage daughter decided to move one of my wheels and let it slam onto its face and destroy the new finish that was less than a few months old. I guess I need to get one refinished #&?!
#129
Bill did you have a chance to try a 993 with Bilsteins before buying the Konis?
What you describe about the Konis sounds very much what I'm looking for. I had been considering either the HDs or PSS10s but am concerned about a harsh ride.
Beautiful car BTW!
Beautiful car BTW!
#131
Beautiful car BTW!
Beautiful car BTW!
#132
Originally Posted by bcameron59
That looks like a SERIOUS alignment shop. Are those jerry cans of (sand? Lead shot?) for weighting the driver's seat?
#133
That is a great stance!
It would be interesting if you could post your ride height in mm from the factory measuring points - especially the back - since the Koni Sport rears are non adjustable (in height) and perhaps the H&R model number for rl-ers for future reference.
#134
#135
So I measured the ride height of my car. Wow, it is a lot lower than I thought it was. I love the look but am surprised how low it is now that I measure it out. I measured 108 front and 103 rear. Here is a pic of the springs. Now I do not know if they have settled since I am not sure how long they have been on the car (since 2000 if that is a date code on the spring). Again, I love this look but had no idea it was this low
https://rennlist.com/forums/993-foru...ce-points.html
