Cowl seal removal
Hi guys,
This was not easy but I've had success and it looks so much better!
Regards,
Regards,
Glad you figured it out, Al. After looking at my car, it seems like the seal is sandwiched in place and secured with the two hex-bolts. Not sure if that was what giving you trouble.
There was so much fine silt like dirt inside the old seal it acted as glue. I ended up using an Armor-All type of product to saturate it. Slowly wiggling and spraying some more lube helped to free it. Pulled it out w/ a pair of pliers wrapped in a T-shirt so as not to scratch the paint.
You will need to remove the hex bolt closest to the windscreen, the second hex bolt back needs to be loosened quite a bit. A flex adapter is the only way to get to it, and I wrapped that in masking tape to give it a bit more stiffness at the knuckle.
I also loosened the top fender bolts down the the wheel.
Installation was pretty straight-forward and much easier than removal. I used one of the tips previously to shave the seal ribs, then placed it in the freezer for an hour. Sprayed it w/ the lube and tapped it in w/ a small rubber mallet after laying an old T-shirt on top.
Interesting to note that the new seal had a felt-like fur on the ribs whereas the original was all plastic, unless that fine silt/dirt I spoke of earlier was actually deteriorated felt.
I did the passenger side this morning and it was much easier.
I'd take a pic but the coupe is now in storage and the cab is back here for some TLC over the next few months.
When is your new baby arriving?
Best Regards,
Best Regards,
