hazard lights used to flash when battery connected
3rd Gear
I have a 993C4 that is driven infrequently so I have installed a battery disconnect between the negative terminal and chassis. When I turn on the switch the hazard lights flash for some 30-60 seconds and then stop.
Recently I had some work done on the car and when it picked it up from the garage the air bag warning light would illuminate for 2 minutes. Of course they said that "we didnt do it and its common to all 993s anyway". I lived with this for several months and noted that when turning the battery on the hazard lights did not flash.
I was able to reset the light with a knockoff durametric I purchased (written about here https://rennlist.com/forums/996-foru...l#post10031141), so everything back to normal. Now however when I turn the battery on the hazard light does not flash.
Questions :
1. why did the hazard lights initially flash when battery power was applied? I presume this was intentional
2 is there an error I can clear or something else I can do to have this flashing return as before? maybe there are other codes to clear
3 this is more of a speculation, perhaps the lights do not return to flashing as before because I used a knockoff duratetric cable and an old software version (not version 5 or 6) when clearing the error?
Anyone seen this before generally with their car or after resetting the airbag light?
thanks in advance
Questions :
thanks in advance
Hi,
I think it has to do with your alarm, when I disconnect the battery and reconnect it the hazard lights will flash once and the sirene will bleep twice.
But then my car has the standard Porsche alarm + an extra after-market alarm (insurance).
