do i need to change the fuel filter part nr: 928 201 081 04 which located under the oil tank. Or i just need to change the fule filter part nr: 928 110 253 06 which located at the engine bay.
I just replaced mine. Mine is 964 but I think it is same. I replaced my fuel line (across the center tunnel) and while I am here, I also replaced the fuel filter you describe and the short rubber fuel line from fuel tank. I am advised that the filter element will disintegrate from time. During the replacement, when it is out, the filter is not too bad. But it is not very expensive items, if while you are there, no harm to change it imo.
Ps. Hopefully ur garage floor is all finished, looking fwd to pictures.
The MaxJax lift is in position, bolted in but not torqued down yet.
I need to get some shims sheared and I prefer using a single full length strip of the appropriate thickness instead of using the half-moons that MaxJax supplies.
The columns are level front to back but are tilting inwards a tad at the moment. If anything, I want them tilting outwards a tad so that they are parallel when loaded.
