Repainting my 1997 993
#46
Emerald
#48
So, since his fenders have been removed for the paint job it will be an easy task getting the weather strip back in.
When I replaced mine I loosened the bolts hoping to get the fender away from the cowl to make it easy to get the new weather strip in. It was almost impossible to get these buggers in. I bought several sets of gaskets. I froze some, heated another set in boiling water and also tried a lubricant. I finally got them in with the lubricant method but they're not fully set low enough.
What puzzles me is....how do they do it at the factory??? The bolts and the weld are painted and yet they're is no paint on the gasket below...it's obvious they are installed after the car is painted.
#49
I stand corrected......it is welded. Phil has a trick where he leaves the weld in place and works the rubber part in with the bolt loosened.
#51
12/02/2012 UPDATE: Sunday Morning outside after final sanding and then into the paint booth this afternoon! Last pics before base coat and clear!
#52
The cowl seals need replacing on my coupe. I have been putting off this job.
Regards,
#54
Phil showed me how he will do it but I would never attempt on my own. Using a small pry bar and loosening the bolt, he works in the gasket using soapy water
#55
Painted yesterday including the hood. Bumper Covers and other parts being painted tomorrow. Wet sanding happening today and tomorrow. Attached pics are pre sanding and include three coats of base black and three coats of clear.
Ready by Friday 12/10/2012? Merry Christmas! AND I can't wait to remove those chrome wheels and replace with my newly powder coated wheels! 8.5X18 235/40/18 Front and 10X18 295/30/18 Rear
Last edited by bella1; 12-09-2012 at 03:21 PM. Reason: Adding Wheels with Tires Pics/Updated Delivery Est
#58
Cant put the clear bra on for a month or so. Not sure Id bother on a repaint. You can reshoot the front for the $600 it cost for a clear bra. If I am saving the original paint I would and have installed the clear bra. Or even wrap it a different color just to have a unique look. saw a flat white BMW Saturday that looked neat.
#59
Good point on the repaint - hadn't thought of that- Makes a ton of sense. I once covered the entire front half of an '06 Boxster S when I first got it. It was nice to have it protected but it always bugged me for some reason - didnt feel right. Chips happen, it's just part of driving a car. I don't think I'd do it again. I'm over it. I do think it helped with resale however...
#60
You are inspiring me to repaint mine!! Even though it is not original paint, I would have a clear bra installed on a fresh repaint, especially a nice job such as yours is.
