Repainting my 1997 993
#31
Bumper Cover Euro Work
The front and rear are almost ready for primer. The front is new and Dave at Eurofinish has placed an insert from a damaged bumper cover where the bumperette holes are located. The work is awesome. Same for the used rear bumper cover where the holes have been filled. When painted you will never know a hole exisited! Car going to paint booth next week.
#32
I'm always in awe of teir one craftsmenship.... bring money O yeah but not always. High quality work is getting harder to find....
Good luck with the project.
#33
Correct
You are right about hard to find. I guess most are not passionate enough to put in the time to learn how it is done. Now I just have to keep others from damaging me when I drive!
#36
A great paint job all depends on the preparation of the surface even before the paint is applied. Hours of sanding and filling, priming and sanding, only to be repeated again before the panels are primed and painted. Additional coats of clearcoat will allow for a good final color sanding and polish to a deep dead flat finish. This type of craftsmanship requires a shop with skilled people with the patience to do things correctly. Your progress looks great!
#38
Do you plan to put an invisible bra in the front? It will absolutely suck to get a rock chip the next week...
#39
Seals
They have been removed as you can see from the beginning photos. There is a bolt that holds the front fender to the cowl. This is loosened to remove that rubber strip. After painting, we insert the rubber and then tighten the bolt.
#41
Hey
I am at VIR thru Sunday. Thanks for the comments and I will get the paint and primer info from Phil next week for those who have an interest. From the prior pictures, the paint does look good. Up close was a different story. Black can be deceiving from a distance.
#42
Monday Update
Bumper covers primed and car wet sanded 400 grit. One more wet sand with 600 and then into the paint booth in a few days. Answers to some questions:
1) I am being advised against a clear bra as the bumper cover and aero parts are being sprayed with 8590 Primer with a Flex Agent. Phil has an older BMW painted in the same manner and his front end shows no rock chips after several years. Still I may put a clear bra on it but after three months at least.
2) Paint used is Spies Hecker where the Base Coat will be Black and then the Clear will be 8035 Spies Hecker Clear.
#43
Thank you for the paint info. I just had my wheels painted as they had road rash from the previous owner. Altough my car is a Cabriolet it has Targa stock wheels. The paint they used was Glasurit. They came out nice. Looking forward to see your car finished.
#44
When the fender/cowl bolt was removed to loosen the fender to get the gasket out did you notice a weld? Also, please let us know how difficult or easy it was getting the new gasket in.
New paint, what a treat! A front end with no road rash.
#45
Fender
No it was not welded. Phil showed me the bolt. On the drivers side, the hex/torx bolt was actually rounded out. So he had to remove the door to back it out. He replaced with new hex/torx bolt. I have seen the old and new gasket. Under the round bead is a flat part that goes between the two metal parts. It looks like it would slide in easily but I will ask
