993 Forum 1995-1998
CA Smog Issues
Old 10-27-2012 | 07:38 PM
Body Roll's Avatar
Body Roll
Default CA Smog Issues
I don't know about you guys, but I dread smog checks like nothing else. This year the car failed smog due to HC numbers that were about 3x too high. The car is a '95 with 107k on the clock, pretty much stock except for the suspension. I always get the car good and hot before the smog check.
The first attempt at solving this was an Italian tune up with techron for two tanks. I also cleaned the MAF. The O2 sensor only has around 20k miles on it so I didn't think it needed to be changed. The result- no change. At. All.
The second attempt was to change the plugs and wires. The wires were original and the plugs had around 20k on them. The result....wait for it.... This worked! No problem hitting the HC spec....the wires were in pretty bad shape so I suspect this was the cause.
BTW- the plugs/wires replacement was a DIY huge job. I'm glad it's not going to come up again for a while....................
Old 10-27-2012 | 08:44 PM
ca993twin's Avatar
ca993twin
Congrats on your persistence and your passing grade. Rufus (132,000+ miles) always passes smog with ease, but AWD cars can't be put on the rollers, so maybe that's a break for me.
Old 10-27-2012 | 09:04 PM
TONY AIR C2S's Avatar
TONY AIR C2S
My *** puckers every time I have to take the car to get a smog check.
Old 10-27-2012 | 09:19 PM
TheBen's Avatar
TheBen
LOL. Me too.
Old 10-28-2012 | 01:09 AM
Ed Hughes's Avatar
Ed Hughes
Mine has had no issues, but got new wires at 45k.
Old 10-28-2012 | 01:36 AM
djantlive's Avatar
djantlive
Changing an o2 sensor helps as well. Congrats! It is good to know the car runs well
Old 10-28-2012 | 02:10 AM
Body Roll's Avatar
Body Roll
It's definitely easier to get an AWD car to pass since there is no dyno test. It's a good reason to go with AWD in CA.
Old 10-28-2012 | 02:11 AM
Kika's Avatar
Kika
Get the car nice and hot, I run around in 2nd gear before I take mine in. Also put a little extra air in the tires, although last time I didn't have to get on the Dyno.
Old 10-28-2012 | 11:01 PM
doublecabmel's Avatar
doublecabmel
If you think the Porsche is hard.... It's next to impossible to smog a Ferrari in the "Communist Republic of Ca"
Quick Reply: CA Smog Issues
