Hollow or Solid twists
Can anybody tell me if these wheel codes are from Hollow Twist wheels or Solid Twists? I checked Pelican but it doesn't say. What is weight difference between the wheels?
993 362 134 06 on the fronts
993 362 140 04 on the rears
islaTurbine (04-10-2022)
Bit more info on the standard 993 fit 18" wheels:
The genuine 'Technology' hollow spoke wheels were available in both normal and wide body offsets as option 408. Here are the specs :
8x18 ET52 (Front - all models) .......993.362.136.00 weight 19.95 lb
10x18 ET65 (Rear - narrow body)......993.362.140.01 - 23.36 lb
10x18 ET40 (Rear - wide body) ......993.362.140.00 - 25.13 lb
Making a good comparison to Turbo Look (solid spoke) as came standard on the Carrera 4S or as option 413 :
8x18 ET52 (Front - all models) .......993.362.136.01 - 25.57 lb
10x18 ET65 (Rear -narrow body) ......993.362.140.04 - 29.32 lb
10x18 ET40 (Rear - wide body) ......993.362.140.03 - 31.08 lb
