993 Forum 1995-1998
HID Blown Fuse Question
Old Oct 12, 2012 | 10:55 PM
Kika's Avatar
Kika
Originally Posted by Pickled Piper
As above. There is an in-rush current spike for a few milliseconds and then the current settles down to s steady state condition. The in-rush spike can be enough to pop the fuse.
However, in the OP's case it does sound like the ballast is toast.
pp
To ignite the HIDS, there is a high VOLTAGE spike, but it is very low CURRENT. Fuses are based on CURRENT draw.
Power in watts is Current in AMPS times Voltage in Volts.
Old Oct 13, 2012 | 12:55 AM
P-daddy's Avatar
P-daddy
Well said Kika. Most kits have low current draw. DDM kits are low draw at 5.x A at start and steady state at 3.x A. Mine definitely was a faulty unit after less than 2 years of very little use. Glad the fuse did its job to protect the wiring.
