993C4 + Nitto NT-05 ??
G'day gents
I am looking for a street/track tyre, can get a good deal on Nitto NT-05's and have read on a lot of tyre tests advising that they are a very good tyre for this purpose
I run stock Cup II wheels, and to date have stuck with Porsche recommended Michelin PS2 255 40/17 rear and 225 45/17 front
Now the NT-05 come in the right size for rear, however the closest they offer to the recommended size is 235 40/17 for the fronts
The 225 45/17 PS2 are 25" overall diameter
The 235 40/18 NT-05 are 24.45" overall diameter
Will the car run well with the Nittos, despite it being AWD and the fronts being 0.55" different overall diameter?
Cheers
Alex
Cheers
Alex
I like this tire size calculator:
http://www.miata.net/garage/tirecalc.html
255/40/17 = 78.6" circumference (rear)
225/45/17 = 78.5" circumference (front-orig, 0.1% difference from rear)
235/40/17 = 76.7" circumference (front-possible NT05, 2.4% difference from rear)
The AWD should be less than ~3% mismatched front-rear, so you are in the range. Also, search "AWD tire sizes" here and there are lots of opinions.
Pseudo-2WD = it just stopped working... It had ~100kmi on it when it stopped, and instances of dead vicious couplers or snapped drive shafts aren't uncommon. I AX the car and like the ability to rotate it and have no need for AWD for "weather conditions", a term we don't use here in SoCal....
