REAR SEAT DELETE JUST LISTED EBAY
Hmm, interesting, but for a grand I guess I can live with using the top of the 'useless' rear seats for placing items on...and I guess I don't really need another little 'door' to fish around in for stuff I have 'stuffed' in there, hahaha.
But looks like a nice job on the 'refinish'...
Jim
Jim
Noodle Jr.
When I restored mine I removed the center divider but also the tie down clips. Looks like this one has the locks everyone talks about for the Cabs.
I had it recarpeted when I bought it and removed the hoops and the bar/divider on the top.
The benefits have been great for me...including being a two seater for car pool lanes (I am in the San Francusco area where many areas require three passenger "unless you are a two seater or a pick-up truck").
Good luck with the "hunt".
The locking mechanism is a solenoid that moves a pin to secure the two doors on the rear seat delete unit. The polarity determines if the pins are engaged or disengaged. I wired mine to a rocker switch I placed in the switch section of the console. I used a factory switch that is double pole, double throw.
It is a three position switch , momentary contact with center position off. The one I obtained has two small white triangle arrows, pointing up and down. The switch is probably a window switch, but it is an exact match to the other switches in the console. I wired it so one of the momentary positions reverses the polarity from the other momentary position....lock and unlock.
I can lock or unlock the doors by pushing the switch one way or the other. This is an old picture that will show the switch…..
That's an older photo...
Changes since then:
Changed to Gemballa Carbon Fiber Steering Wheel.
Removed cell phone / added Bluetooth
Relocated Radar (Valentine V1) to behind rear view mirror.......
Changes since then:
Noodle Jr.
