993 Forum 1995-1998
Glovebox won't open
Old Sep 14, 2012 | 11:14 PM
RJKK's Avatar
RJKK
Default Glovebox won't open
OK, not up there with problems I could have and not the glovebox door loose issue with good DIY's. Mine no longer opens..
**** turns but won't release the catch. I removed the bottom screws, thinking the door would come away but no dice. Holding fast.
I tried worrying the door off the latch but am worried i will break something...
Anybody run into this issue?
Thanks!!
Old Sep 15, 2012 | 12:42 AM
RJKK's Avatar
RJKK
Default Glovebox door won't open - update
Update:
For anyone else that runs into this problem; With bottom hinge screws (3) removed, door will come off - pull up from bottom with slow even upward pressure. Latch will pop off and the side stops so be prepared.
Issue is the nut that holds the **** together (under black cover on left) only needs to loosen up a little for the plastic cam to slide over latch arm vs push the arm to release the latch.
Tighten nut, realign cam cover - screw down, spritz arm with some silicone etc, - replace inner door cover - insert side stops and reattach bottom hinge. Door is tighter now and opens fine...
Old Sep 15, 2012 | 10:21 AM
lopro's Avatar
lopro
does this happen often ? I had been having this issue also, thanks for the advice.
Old Sep 15, 2012 | 08:09 PM
RJKK's Avatar
RJKK
The culprit for me may have been a recent DE day. Between use and bouncing around I can see nut under the cam cover loosening up occasionally. I'm going to check now from time to time. I can see it now.....seriously officer, I would give you my registration but my glovebox won't open....not expecting any mercy on that excuse.
Old Nov 14, 2012 | 09:00 PM
porker999's Avatar
porker999
5th Gear
I have a somewhat different glove box issue that I wondered if anyone could help with:
On my 2008 C2S, the glove box door has lost it's "damping" effect. It no longer lowers slowly, it just falls open.
Is this something I could fix myself? Is there a hydraulic strut of some kind that I can replace?
Old Nov 14, 2012 | 10:53 PM
Jeff96-993's Avatar
Jeff96-993
2008? Here?
Old Nov 14, 2012 | 11:14 PM
Dryfly57's Avatar
Dryfly57
Funny, mine wouldn't close......
Old Nov 15, 2012 | 03:16 PM
porker999's Avatar
porker999
5th Gear
Yep, it's a 2008.
Any help?
Thanks...
