Do major mods to our cars 'make sense'?
#47
Watch what happens when the 991GT3 comes out.
#49
The single biggest flaw to me is the transmission. To much split. Winding in second and ******* in third. The reson I know this is I sold the car because of this problem and bought a G-50 Carrera that has a true active gearbox. I cant believe the differance. When you run it up thru the gears shifting at 7200 the gear split brings the next gear in at the exact moment the varioram opens up and the motor is just wailing .
here are the drops for a G50.00 US Carrera(RoW is so similar as not to be worth showing), G50.20 US 993 and G50.30 CUP/RSR
![](https://forums.pelicanparts.com/uploads21/RPM_drops_5vs61346957773.gif)
the only time a 5 5speed Carrera(US '87-89) has more advantageous drops than a 993 g50/20 is from 1 to 2, 2 to 3 is so close that we can call it a tie, but from 3 to 4 and up the g50/20 has closer ratios
I still say that the /30 used in Cups and RSRs is just about perfect
#50
I don't know how you can say that
And I'll bring up the nasty side of regearing yet again--my yellow car at Laguna. Absolutely, positively costs me 1-1.5 sec/lap. But absolutely, positively of benefit at Sears and Thunderhill. (A stock 964 5 speed works great at all three circuits.)
#51
Here are your drops
![](https://forums.pelicanparts.com/uploads21/RPM_drops_5vs6_21346969846.gif)
#52
I'm showing a 1300 rpm drop 4-5 on my data at Thunderhill. (Don't touch 5th at either Sears or Laguna.)
#54
a bone stock, clean 993 is a beautiful thing. It is the way we like them.
easy mods are welcome such as exhaust, key fob retrofit and suspension bits.
Body alterations are risky.
anything that can be undone is cool.
#55
#56
OK, now I'm confused on the first chart. Cuz that yellow line shows a 4-5 split of 2K rpm, which is the 5-6 split.
(And my actual numbers vary slightly as I run the inch taller tire in a 275/40-17 or 275/35-18.)
#57
![](http://forums.pelicanparts.com/uploads21/RPM_drops_5vs6_21346969846.gif)
x axis is From and each gear is indicated, 4 is from 4 to 5
#58
So the outlier there on the right is 5-6. I'm not shifting into 6th anywhere in the West Coast track known universe.
What exactly then is so screwy about the ratios?
#59
and of course you have the stock very low 1 which gives the big drop going from 1 to 2 which is also not used on most tracks but is one of the most detested, after the overly tall 6, stock ratio for street use
Small apparent differences in the charts make for relatively large seat of the pants difference on a track
