Mobil 1 Autozone $10 Coupon
Addicted Specialist
Edward
Check the specs on Mobil 1 and you will see that the level of ZDDP is now down in the 700 ppm range.
Prior to the new EPA regs, Mobil 1 carried ZDDP at levels in the 1300 to 1500 ppm range. Sorry for the bad tidings.
There are work arounds, but I didn't want to turn this thread into another oil discussion thread. Just do your research.
The attached PDF highlights 3 different M-1 engine oils with ZDDP above 1300 ppm.
