Alignment in SF Bay area (Peninsula)?
Well, I guess it's hard to determine how many miles "a week or two" involves, but I'd say there's no reason to drive that long w/ your suspension out alignment. You could chew up your tires pretty badly if the initial settings aren't close.
Assuming it was installed correctly to begin with, drive it around the block a few times, go over a few speed bumps, and you should be fine.
I didn't realize Darin was actually installing -- thought you just bought the parts from him and were installing yourself. You should be fine driving that distance w/o worrying about tire wear if he installs the suspension.
