Fister stage III's installed, my thoughts
Just wanted to share my opinions about the stage III's compared to stage II's as I had experienced both. Started with the II's being conservative, middle aged dude who has had his fair share of loud exhaust cars growing up. Time for something mellow. II' are definitely mellow. They have a nice little bark when you fire up which settles to a gurgle at idle. Once underway, the mellow exhaust noise is overcome by wind, road noise at around 40mph. So cruising at 40- 60mph, 2000 - 3000 rpm, no exhaust noise can be heard. I wanted to hear something while cruising, so the stage II's were sent back for the stage III's. The III's have a very sharp bark at fire up and settles to healthy deep gurgle at idle. But it is nothing too crazy. Once underway it is noticeable that the III's are louder than the II's but once again not too crazy, quite pleasant actually. At cruising speeds, the exhaust note is there but not blaring. In fact, windows up, cruising at highway speeds exhaust note is just barely perceptable. Perfect.
Of course this is just my humble opinion, based on my ears sitting in the drivers seat of my stock 97 Carrera with motorsound option, undertray installed. I have no impressions what the car sounds like on the outside to others yet.
FD motorsports was a pleasure to work with, and will recommend them to others.
Wolfgang
At 993Fest, we did an informal 'sound-off' of various exhausts. Granted until recently I'd been in the 'Murican fire-breathing V8 camp, but even Supercups I didn't find to be nearly as loud as people made them out to be..you guys are just old.
It looks to me like you used Nylock style lock nuts on your clamps. Those will eventually heat up and melt causing the nut to work itself off. I learned the hard way. Need to use distorted thread style lock nuts. I'd also put washers inbetween the clamp and bolt head and nut like the factory does.
A month ago I installed stage IIIs and am very pleased with the sound. Just right. Two days ago I upgraded to a SW chip and I could swear the exhaust is now quieter. Am I just imagining this or could the timing advance in the mid-range rpms quiet down the exhaust? Anybody else have he same experience?
