Clock removal question
I am trying to remove the clock from my dash to give me access to run some wires behind the dash for a remote radar system I am installing.
I found a few suggestions on line, but have had no success. It is in pretty tight.
Any tips on how to do this and, avoid any dings to the dash or trim rings?
I tried with each with no success.
I don't want to damage the dash and end up having a permanenet indentation in the vinyl/
The rubber rim around the gauges reatinthem in the dash with ribs?
correct?
Go between rubber and dash or between rubber and gauge?
correct?
Go slowly and it will move. Then work the lower right side. You should get it to a point where you can then pull it out.
Hope this helps.
Try wrapping the screwdriver flat head in a microfiber towel, thin cloth or something to protect it from possibly damaging your interior.
I did this and it allowed me to dig the screwdriver in further without damage.
