993 Forum 1995-1998
Horn goes off when braking?
Old 07-03-2012 | 11:14 AM
Pags993's Avatar
Pags993
Default Horn goes off when braking?
I know this topic has definitely come up before but the search function is not bringing anything up on the subject?
Any quick fixes, kits, simple adjustment that can be made? getting kind of emabarrasing in traffic LOL
Thanks in advance.....
Old 07-03-2012 | 11:24 AM
RocketJohn's Avatar
RocketJohn
steering wheel bushings on a plate that keeps the airbag weight off the horn... the 95s take a different part than the 96+... My dealer had to fix mine before I took delivery last week... ordered a 96, drilled out the bushings and installed them on my 95 part... there are some threads onhere and Pelican to help you through...
https://rennlist.com/forums/6818602-post18.html
https://rennlist.com/forums/993-foru...ing-frame.html
Old 07-03-2012 | 12:26 PM
JimPA's Avatar
JimPA
An easy fix is cutting pieces of hose or building up a layer of silicone (which takes time to dry so not as "quick) for each bushing. I used silicone, which lasted a couple of years. The second time, I installed a new horn frame.
Old 07-03-2012 | 12:31 PM
BHMav8r's Avatar
BHMav8r
There truely is nothing you cant find out on RL.
Old 07-03-2012 | 01:10 PM
Pags993's Avatar
Pags993
Agreed, this place is unmatched re info and knowlegde!
Old 07-03-2012 | 02:20 PM
Silver Box's Avatar
Silver Box
Warmer weather must be impacting those bushings (maybe making them softer than normal??). Mine started doing this Sat. after being out in our record 107 degree heat.
Old 07-03-2012 | 02:21 PM
swmic's Avatar
swmic
I've used "shoe glue", which dries quicker than silicone, to help stiffen up the little bushings. Worked well, but the best solution is replacing the bushings.
Old 07-03-2012 | 02:32 PM
Michael S.'s Avatar
Michael S.
It's an easy fix... replaced my horn support about two years ago... Maybe takes 15 minutes if you are really slow. Don't remember the cost exactly, but it wasn't expensive...
Old 07-04-2012 | 02:16 PM
KBell's Avatar
KBell
I have a '95.
Mine started also in this extreme heat (temp 105') and on hard braking.
What timing.
I love this place
Old 07-04-2012 | 02:23 PM
gaby1088's Avatar
gaby1088
if you dont want to fork up the $XX (i think its over 50) you can put some bubble wrap wrapped in seran wrap and some silicone where the bushings go and it works perfectly fine.. thats what i did.
Old 07-04-2012 | 04:57 PM
jaholmes's Avatar
jaholmes
Mine just started. I fell like an idiot when it goes off braking at a light. Heat for sure. It's 90+ in IL now.
Old 07-04-2012 | 08:30 PM
BradB's Avatar
BradB
Horn when braking, Hmmm...It could be from the guy BEHIND you!
Old 07-04-2012 | 09:03 PM
Falcondrivr's Avatar
Falcondrivr
We need a sticky thread with the title:
"If your horn honks when braking, if your odometer has stopped working, if your window won't go down, click here for the answer."
Old 07-05-2012 | 10:03 PM
Pags993's Avatar
Pags993
thanks for all the suggestions all, just yanked the fuse for now until i can set aside some time to replace the bushings.
Old 07-05-2012 | 10:22 PM
Gt3 Racer RS's Avatar
Gt3 Racer RS
What if you need the horn??? U GONNA DIE!
Quick Reply: Horn goes off when braking?
