993 Forum 1995-1998
AC vacuum recirculating valve problem
Old May 7, 2017 | 01:22 AM
drb930's Avatar
drb930
Originally Posted by osugasman
I also need the "highly prone to failure after 16 years" mixer valve motor--passenger's side. While troubleshooting it, I noticed that the ?pin? that connects the vacuum motor to the articulating arm on the recirculation intake structure had "disappeared". Pump fully functional. Fixed it by convincing a zip tie to crawl in there and offer up his one and only shot at fame by being utilized in a Porsche. Now fully functional. While awaiting the mixer motor, I simply closed the flap valve (tested it with heater on high--no movement towards opening) and have deliciously cold a/c just in time for the >100 degree Cincinnati weather this week.
I should have searched 1st. Just started a thread on this same problem.
Has anyone come up with a p/n for the actuator arm connector or something to use as a replacement?
Seems a waste to replace the whole valve assembly for some kind of connector pin.
Thanks,
Dave
