993 Forum 1995-1998
Oil filters
Old May 30, 2012 | 07:35 AM
ollster's Avatar
ollster
8th Gear
Default Oil filters
Car is being serviced next week, and i wondered if anyone had a preference as to which oil filters to use. I know Porsche used to supply German made mahle oil filter but now supply usa made filters which some suggest are inferior quality wise to those originally used.
If the above is true it would seem to make my decision easy but I have also read that the mahle filters caused issues on 993 tt's a few years ago by allowing oil to flow back into the turbo's on shutdown and you should only use Porsche supplied OE filters on this model. My car is an NA but if it caused an issue on the turbo's and the OE filters was recommended is the situation the same for the NA's?
Old May 30, 2012 | 07:49 AM
e9stibi's Avatar
e9stibi
Yes, you read correctly. For Turbo models you should go OEM. For NB, plenty of people like myself are using Mahle or Mann for years. I get my basic supplies from pelican.com
Old May 30, 2012 | 07:50 AM
randytrish's Avatar
randytrish
Are you doing the service or a shop? If it's a shop, what do they recommend? I use mahle filters and haven't had any issues that I know of.
Old May 30, 2012 | 08:01 AM
ollster's Avatar
ollster
8th Gear
Cheers for the input, my local specialist will be doing the service (just for the stamp in the book really). Im not trying to save money i just want the best filters for my car and have noticed a lot of parts i have bought from Porsche recently have been inferior quality to the ones i took off!
I am just a little concered with the whole issue surrounding mahles use on turbo's as even though i have an NA it would suggest the check valve does not seal correctly.
Old May 30, 2012 | 08:30 AM
geolab's Avatar
geolab
best oil filter for your carrera is the porsche filter, especially the small one.
Porsche issued a TSB on this issue, and the TSB was destined for turbo AND carrera.
The filter issue was not the fact that it was allowing oil back, but the contrary. It kept the post oil in the galleys pressurized.
regards
here is the TSB
http://www.pcarworkshop.com/images/3...0395geolab.pdf
Old May 30, 2012 | 08:48 AM
ollster's Avatar
ollster
8th Gear
interesting thanks for that, i would assume when that tsb was released mahle were the OE filter supplier to porsche so would it be fair to assume that 993 107 203 02 would have been a redesigned mahle filter at the time, and by that logic the current OEM available mahle filters should be ok?
Old May 30, 2012 | 08:56 AM
No HTwo O's Avatar
No HTwo O
FWIW, my indy shop uses Mahle filters on the 993/993TT without issues. I've used the Mahle filters on my Turbo the past 2 years without issues. With that said, I just had my oil changed last week, and insisted on the Porsche filters, and will continue to do so in the future.
Old May 30, 2012 | 09:50 AM
911PERVY's Avatar
911PERVY
Yes, I think you have it correct, although the part is now 03 & 02 ending due to the Mann manufacturer
Old May 30, 2012 | 10:36 AM
vincer77's Avatar
vincer77
I used Porsche OE filters last change and from Sunset, they were only a couple dollars more than the Mann.
Old May 30, 2012 | 10:52 AM
911PERVY's Avatar
911PERVY
Porsche ones are Mann......................were Mahle/Knetch
Old May 30, 2012 | 03:53 PM
badabing's Avatar
badabing
I used the Mahle filters (from Pelican) once on my TT with disastrous results.
Filters from Porsche dealer only.
Old May 30, 2012 | 07:34 PM
vincer77's Avatar
vincer77
Stand corrected. Large filter was Mahle/Knecht and small was Mann (from Autohaus AZ). Last ones I used from Sunset were packaged in Porsche boxes - did not look to see if they were stamped with Mann.
EDIT: Also, while on the subject, there was a thread that talked about smoking on startup. Someone suggested that an oil filter bypass update was done on the OE the filters that prevented it from happening. It may only be for the Turbo that that is important. Anyway, I started my car after it was sitting for a bit and it smoked.
Old May 31, 2012 | 10:09 AM
IXLR8's Avatar
IXLR8
And the Mahle oil filters I get from them are made in Austria.
Old Jun 1, 2012 | 11:53 AM
pp000830's Avatar
pp000830
My opinion is that there is only one feature on an oil filter that matters. Some filters have a valve that keeps the oil filter full of oil when the engine is off. You can see the valve by looking into the filter from the bottom. I believe the valve helps the system flows oil immediately at startup. If your oil filter is oriented vertically and screws in from below I am not sure the valve does anything for you. Other than this my opinion is the cheaper the better. One that comes free when you buy oil on special is best. Look at the filter you buy and make sure the screw on interface is clean and bright. Some filters form rust in the box on the store shelf and I would not want to put one of these on my 993.
Old Jun 9, 2012 | 10:08 PM
vanguard's Avatar
vanguard
so what is the consensus for non-turbo cars? just stick to OEM since they are just few dollars more? where's the best place to buy the filters?
