This whole issue of using only Porsche filters is absurd. 993 turbos need a pair of check valves installed to prevent smoking. After that you can use any filter you want and the turbo car won't smoke.NA 993 can use any filter.If you change your oil every 3k you can replace the filters every other oil change.Don't believe the hype. The cars were designed to have 15k miles in-between oil changes for street use.The dual filter system on all 993's is redundant by design.
