Rear seatbelt not retracting fully--what are my options?
The belt extends out all the way and holds tight when yanked, but when released it will only partially retract and then sag.
I can get it to fully retract by feeding it back in.
If it's not fully fed in it will not extend again next time I pull it to use....must be fed all the way back in again to use.
I put my 6 yr old back there and with the booster seat and I have to remove the belt each time from the shoulder strap to feed it all the way back which is kind of a PITA.
I have a feeling it's just going to get worse quickly so I'd like to remedy.
The belts are Guards Red so expensive to replace. This is the rear passenger side. The rear drivers side works perfectly (never used actually) and if swapping the two is feasible, it would be my preference.
I didn't see any DIY or instructions on replacing these (if that's what has to be done). I assume the rear trim would have to be removed. Any help or options would be appreciated. Hopefully there is an easier fix.
I just noticed that my belt retractor for the drivers seat is starting to do the same thing....i havent started researching options like replacement with a new or used tensioner, or swapping,but ill let you know what i find out.
https://rennlist.com/forums/993-foru...-assembly.html
Sounds like this is a very common problem - there are several possible simple solutions to get it operating properly again - just do a search for rear seat belt and you'll see a bunch.
