Speed cam ... red light plate cover ...
My beef is with the law, as written for my locality. The following two cases would be ticketed the same:
Case 1- Yapping on the cell phone, not watching, light changes, they notice late, and race through the intersection - 1 second into a red, with heavy traffic.
Case 2- Pulled up to the light as it turned red, in the right turn lane, no cars in sight, light traffic day. They did not come to a complete stop before turning right.
Case 1 $262 fine.
Case 2 $262 fine.
Black and white, you ran a light, both generate a fine. Which one really is deserving of the fine?
Unfortunately, there is no difference in letter of the law and intent of the law with the red light camera.
Case 1 $262 fine.
Case 2 $262 fine.
Case 1 $262 fine.
Case 2 $262 fine.
Case 1 $262 fine.
Case 2 $262 fine.
A stop is a stop.. I think if they wrote it another way every case 1 would fight it and work a loophole. I got busted rolling\yielding through a yellow that turned red.. I knew I was pushing it, but smiled for the camera. I thought it wasn't thaaaaaaat close until I watched the video :P If you drive, work a few $100 into ticket taxes.. they ultimately keep the roads safter - not perfect, but it's progress.
phil.
It works???
I sent a can of photo blocker spray to a buddy in NY. Then later he gets a ticket in the mail, from a speed camera, not a red light camera. His front license plate was blocked, as advertised by Photo Blocker. BUT, the camera was so good, in the pic of his front windscreen, the NY state sticker was detected, and they sent him his pic showing the front plate was indeed blocked out, but NOT the NY state sticker.
The front sticker had enough detail for him to be readily tracked down. He paid the ticket.
Because, I would typically carry on safely thru the intersection if I werent worried about a super short yellow followed by a $300 ticket in the mail. It causes people to react differently and erratically and therefore causes accidents.
That being said, I def cannot stand the idiots who are yapping away and not paying attention, so they clearly go strait thru a red light and they worst is they don't even realize what they just did! The problem with traffic cameras in general is they penalize you after the fact...they are only about revenue, not safety. As soon as people catch onto them and they no longer issue enough tickets to pay to keep them on, they turn them off - that tells me its about revenue.
R.I.P
Not above the law types, just one of the types that doesn't want some jackass in a truck tailgating me in my Porsche ramming me into the intersection when I brake for the red and he cannot stop.
Thanks Martin, this is the ONLY response that comes anywhere close to answering the OP's question.
Cheers
Craig
Former Vendor
FYI: In California the minimum fine for running a red light whether it be camera equipped or not is $460.00.
Our suggestion is to not run red lights and spend the $460.00 on someting cool for your 993.
Team GT3 TEK
Team GT3 TEK
The problem with many of the plate blockers is that a police officer can tell that you have one on and will pull you over and issue you a citation for it or make you remove it.
There are numerous places in Baltimore city where people have complete disregard for a red light and will punch through an intersection, nearly T-boning another car. It's incredibly dangerous. I have no problem with red light cameras.
The cameras are pretty darn good so good luck blocking. Around here you could probably just take your plate off and I doubt you would get pulled over. Once in awhile I threaten to burn donuts in a major intersection because apparently you can get away with nearly anything unless a camera is involved. Enforcement of driving laws is nearly non-existent.
After 19 years of driving a 911 ('89,'95,'96), and 325,000 miles in one, I am always aware of what is behind me when I plan to come to a stop. When cars follow too closely I slow down so that they don't hit me in the rear if I slow down or stop. I can only remember one occasion where I actually went through a red so that I didn't get rear ended by a tractor trailer, but I was able to see that there was no cross traffic. Early on when I first could afford a fast car I had the opportunity to go to traffic school in Virginia, twice. The yellow light means stop, not speed up. If you make a habit of going through yellows that turn red on you you deserve the ticket. Occasionally you'll get one because of an unavoidable situation and you can go fight it or pay the fine. If this is happening to you often you need to acquire better driving habits. Man up!
R.I.P
Im glad you got a chance to attend traffic school
The yellow means you should prepare to stop in time if its safe to do so - it is by no means an obligation to stop.
The percentage of time it happens might be low, but if it happens to you its 100%.
The yellow is intended as a warning that the light is about to change from green to red. You should always stop on a yellow unless you're so close to the intersection when it turns yellow that you won't be able to stop safely. In that case, put your hands over your eyes and floor it.
